'87 Comanche clutch question
Conejo
PostPosted: Mon Apr 21, 2008 8:13 pm    Post subject: '87 Comanche clutch question Reply with quote
Hey guys!
I just bought an '87 longbed 4x4 Jeep Comanche, i'm pretty excited about it.
But the prominent issue at hand is the clutch is not working properly. I only drove it briefly today, but heres the working description as of now:
I can depress the clutch which has what I would call normal tension on it but once I shift into gear and release the clutch it takes it awhile to really "catch" gear and even at that, it doesn't catch completely. It feels like when you halfway hold the clutch in while at speed so you're getting about half as much hook-up and power as it feels like you should be getting.
Any ideas?
Thanks much guys and I'm sure glad I found yall! I'll have pics up soon enough.
Conejo
djgrayxj
PostPosted: Tue Apr 22, 2008 5:12 am    Post subject: Reply with quote
What engine do you have [plus mileage] and do you have oil leaking from the bell housing? 4.0 engines do have a problem with rear main seal leaking, if you do oil may be acting as a lubricant between the flywheel and the clutch disk, which will cause the clutch to slip. First thought towards solution.
From Sticky: XJ Teck wrightups above
REAR MAIN SEAL REPLACEMENT
http://jeepin.com/features/rearmain/index.asp
Conejo
PostPosted: Tue Apr 22, 2008 7:08 am    Post subject: Reply with quote
It does have the 4.0L motor in it matched to a 5-spd. It has 141K miles on it and has never been overhauled or replaced. I didn't notice any oil leaks, but I haven't had time to really inspect it yet so I'll check the bellhousing today. Thanks for the quick response!
