4wd not shifting
coastiejack
PostPosted: Thu May 08, 2008 3:01 am    Post subject: 4wd not shifting Reply with quote
i have a 92 yj and i just recently installed my SYE on it. now the darn thing will not shift 4wd easily.......any ideas.
PROUD MEMBER OF RED SOX NATION SINCE 1999
ALSO ON MILITARYJEEPERS.COM
PostPosted: Thu May 08, 2008 8:34 am    Post subject: Reply with quote
Check the linkage first. It could be off a hair.
coastiejack
PostPosted: Fri May 09, 2008 2:06 am    Post subject: Reply with quote
how can i check that Embarassed
PostPosted: Fri May 09, 2008 9:09 am    Post subject: Reply with quote
http://jeephorizons.com/phpbb/viewtopic.php?p=14214
PostPosted: Fri May 09, 2008 10:30 am    Post subject: Reply with quote
This is from a Hayne's 87-03 Wrangler Manual. Slightly different setup from the XJ schematic. Plus, it's in English. Hopefully this will solve your problem. Did you install the SYE or did you have it done?
coastiejack
PostPosted: Mon May 12, 2008 2:18 am    Post subject: Reply with quote
i installed it myself..thanks for the post up i will get to this this weekend
