Coolant bottle leaks-Convert to open?
91 Cherokee
PostPosted: Sun Apr 27, 2008 6:30 am    Post subject: Coolant bottle leaks-Convert to open? Reply with quote
Hi,
On my 1990 Cherokee, my coolant bottle caps will not stay tight. The threads on the bottle act like they are stripped or too small. I have tried 2 bottles and 4 caps...tired of wasting money on a lousy closed system.
Any of you ever heard of too high pressure in the coolant system?
I bought a radiator for it a couple years ago before I knew to convert it to open so now I am looking for a radiator cap housing that will slip into the radiator hose.
Someone said Summitt sold one but I cannot find it on their site.
Any help y'all might have will be appreciated. I am tired of leaking coolant.
Eric
PostPosted: Sun Apr 27, 2008 9:14 am    Post subject: Reply with quote
I found them in less than a minute....search is your friend. Wink
Radiator Hose Fillers at Summit racing
If that link doesn't work, just do a search on "Radiator Hose Fillers". They have 10 or 11 different ones.
mexirican
PostPosted: Sun Apr 27, 2008 4:49 pm    Post subject: Reply with quote
You rock Phantom! I was looking into the same thing. Thanks for the help.
91 Cherokee
PostPosted: Sun Apr 27, 2008 4:56 pm    Post subject: Reply with quote
Like mexirican said...thanks alot, exactly what I was looking for.
Eric
91 Cherokee
PostPosted: Mon Apr 28, 2008 7:18 am    Post subject: Reply with quote
Phantum,
Do you think it would work just as well in a heater hose as compared to the top radiator hose?
I can place it higher if a heater hose is OK.
Thanks
Eric
PostPosted: Mon Apr 28, 2008 9:18 am    Post subject: Reply with quote
It should go in the upper radiator hose, as close to the radiator as possible.
91 Cherokee
PostPosted: Mon Apr 28, 2008 8:06 pm    Post subject: Reply with quote
10-4, thanks.
Eric
mexirican
PostPosted: Sun May 04, 2008 9:48 pm    Post subject: Reply with quote
91 Cherokee, you should also get a new tank. I have a 1990 too and my tank was leaking. They are only $20 and this place sends them next day. http://www.drautoparts.com/items/item.aspx?itemid=9328570
91 Cherokee
PostPosted: Thu May 08, 2008 10:28 am    Post subject: Reply with quote
Thanks m, but I plan on converting it to open.
Eric
