exhaust manifold stud broked off 99 grand cherokee laredo
mgilpin1
PostPosted: Tue May 13, 2008 6:05 am    Post subject: exhaust manifold stud broked off 99 grand cherokee laredo Reply with quote
Confused I have a 99 Jeep grand cherokee with the rear bolt rusted or broken off. This is the one one the drivers side and it holds the heat shield on as well. Is there a good way to get the broken bolt out and what size stud do I need to replace the broken one. Thanks in advance![b][/b]
Mark Gilpin
PostPosted: Tue May 13, 2008 8:55 am    Post subject: Reply with quote
Do you have an 8 or 6 cyl.? Is the stud broke off flush with the manifold? I would say the best way to remove it would be to remove the manifold, then the rest of the stud should be sticking out enough to grab with some vice grips. Not sure of the stud size, but if you remove one of the others, you'll have it.
