Ignition Alarm
Nikita6057
PostPosted: Sat May 17, 2008 5:40 am    Post subject: Ignition Alarm Reply with quote
My TJ wrangler has a alarm that sounds whenever u leave the key in the ignition but do not have the engine turned on, does anyone know how to disconnect this.
bubbaedc
PostPosted: Sat May 17, 2008 7:59 am    Post subject: Reply with quote
do you have an aftermarket alarm on there that you know of?
'98 TJ
dana 60/44 combo
PostPosted: Sat May 17, 2008 9:05 am    Post subject: Re: Ignition Alarm Reply with quote
Just pull the key half way out, and the chiming will stop.
Nikita6057
PostPosted: Fri May 23, 2008 4:50 am    Post subject: Reply with quote
The car does not have a aftermarket alarm, it only sounds if the key is in the ignintion and the doors are open or if you havent actually started the car, i know if i simply take the keys out that it will stop, but some times it is more convenient to have the keys in the ignition before the car has actually been started.
PostPosted: Fri May 23, 2008 7:20 am    Post subject: Reply with quote
Then close the door.
TJ Apex
PostPosted: Fri May 23, 2008 9:45 am    Post subject: Reply with quote
I know your torment, removing the chimer is the first thing to my TJ.
The chimer is located on the back side of the dash pod. To get to it you have to take your whole dash apart and remove the pod. If I remember the chimer is rectangular with a hole off to one side and looks like it pulls out of the socket. It's not that hard to do, just take your time and remember witch screws go where, some parts of the dash have "snap in" type retainers witch make removal and replacement easy.
Good luck
2002 Wrangler Apex
Welfare recipients should pass a drug test to get paidů
02' Apex Edition,
2" BB, 31" BFG AT's
Jeep_addict
PostPosted: Fri May 23, 2008 7:20 pm    Post subject: Reply with quote
You can also pull the dome light fuse.
