Electric / Secondary Water Pumps?
Swiftek
PostPosted: Thu May 22, 2008 7:49 am    Post subject: Electric / Secondary Water Pumps? Reply with quote
Anybody know of good electric and/or secondary water pumps for the 4.0 liter inline 6 cylinder engine?
Swiftek
www.PinellasPC.com
'89 Cherokee Pioneer "4x4x4"
(4WD, 4Liter, 4Door)
PostPosted: Sun Jun 08, 2008 11:40 pm    Post subject: Reply with quote
no they don't need them .
Swiftek
PostPosted: Thu Jun 12, 2008 8:42 am    Post subject: Reply with quote
Shocked
Well, now I'd say that is a matter of opinion.
In my area, the ability to sit in heavy traffic at ambient air temps over 110 F is very important. An electric or secondary pump would overcome the problem of low coolant flow at idle.
Swiftek
www.PinellasPC.com
PostPosted: Thu Jun 12, 2008 1:44 pm    Post subject: Reply with quote
Instead of reinventing the wheel, have you looked at a high flow thermostat housing and something like a flowkooler waterpump? It's worked for me at low speeds in the desert. You can also look at something like this.
Swiftek
PostPosted: Thu Jun 12, 2008 2:04 pm    Post subject: Reply with quote
Thanks for the suggestions.
I'm not reinventing anything. Electric primary and secondary pumps are becoming more popular and don't require any new engineering.
The flowkooler is an option that I've considered along with some other high-performance replacement pumps.
The probs I'm referring to are not at "slow speeds", but only at dead idle. There are no restrictions in the OEM thermostat housings or any other water channels. The only problem at idle is the lack of pressure due to the clearances on the OEM pump. Even a few revs above idle are enough to move coolant and keep it cool.
I'm just looking for something I can add or replace that will be more than what is needed by a factor of 2 or 3. A secondary electric inline pump seems to be what I'm looking for, but my mind is still open.
Again, thanks for the tips. I'll read thru it.
Swiftek
www.PinellasPC.com
PostPosted: Sat Jun 14, 2008 11:30 am    Post subject: Reply with quote
I honestly can not see why this is needed. There are a lot of Jeepers across this country and many in extremely hot places like the Southwest US that are hotter than Tampa. Never have any of them spoke about needing a secondary water pump or an electric primary pump so engine RPM doesn't effect the flow rate. Many of these guys run AC while offroad and baking in the desert sun.
Good luck in your search.
Swiftek
PostPosted: Sat Jun 14, 2008 12:55 pm    Post subject: Reply with quote
I tend to agree with that.
Perhaps I am missing something that is causing my issue. I'm certainly open to the possibility. I have done a test that shows very little flow and almost no pressure at idle RPM. If I put my hand over the end of the top radiator hose at idle, the coolant flow simply stops. Even the slightest rev will force water past my hand.
I think I have verified everything... I have a new radiator, oem pump, thermostat and hoses. I have verified no blockages in the water jackets, and there is good flow thru the entire system.
I guess I should do a compression test to check for a blown head gasket, but I have no other symptoms that would suggest that. The oil looks good and gets changed properly.
Could a bad auto-transmission be dumping too much heat into the radiator? I guess now is the time to add that separate trans cooler, eh?
That's why I'm here... looking for ideas. Thanks for reading.
Swiftek
www.PinellasPC.com
PostPosted: Fri Jul 18, 2008 10:30 pm    Post subject: Reply with quote
you dont by any chance still have the closed cooling system found in a 89 Cherokee .
no rad cap , pressure bottle .
works in some vehicles , but not a cherokee very well .
Swiftek
PostPosted: Sat Jul 19, 2008 8:37 am    Post subject: Reply with quote
Yes, it is the closed system, but I can't see how that could be the problem honestly.
Swiftek
www.PinellasPC.com
