2 tags on the diff, 1 is ratio, whats the other one?
aerostarlegacy
PostPosted: Fri May 30, 2008 10:47 am    Post subject: 2 tags on the diff, 1 is ratio, whats the other one? Reply with quote
There are 2 tags on the pumpkin, one says 3.07 (I assume that's the gear ratio) and the other says 2994. I looked around and found that it might be build codes, or towing capacity (2994kg=6600lbs). Which (if any) is it?
Yes, I have a Jeep
Yes, it is awesome
Yes, I can go off road
No, you may not drive it
