Sluggish Starting - 4.0L High Output
Tim Hallam
PostPosted: Mon May 26, 2008 5:29 pm    Post subject: Sluggish Starting - 4.0L High Output Reply with quote
I was wondering if anyone else has had this problem or knows how to fix it.
1993 Cherokee Sport.
4.0 H.O.
Auto.
170K.
It always starts in decent temperatures but it takes about 5-7 seconds before it fires up. In cold weather however, sometimes it won't start for a couple minutes and takes a little gas pedal pumping to get it fired up.
The starter is brandnew and all the spark plugs are fresh.
The guy my girlfriend bought the Jeep from said that he had had starting issues with it before but after replacing the starter it was ok, it just took a little while to fire up.
I'm just curious if there is some kind of a magical fix to this issue or at least if someone can tell me why it's so sluggish starting, that would be great.
Thank you -
Tim
okcjeeper
PostPosted: Mon May 26, 2008 6:04 pm    Post subject: Reply with quote
How new is the cap and rotor? Also could change the ignition coil...
96sportster
PostPosted: Tue May 27, 2008 5:48 am    Post subject: Reply with quote
i have the same problem, i havent done anything to really fix it cuz it always starts first try jsut after 2-5 seconds... i put some injector cleaner in idk if it really helped, but def didnt hurt
Tim Hallam
PostPosted: Tue May 27, 2008 9:08 am    Post subject: Reply with quote
Thanks for the replies, I appreciate it.
I don't know how new the cap and rotor is but I'm glad those items aren't insanely expensive. Thanks for the input.
Tim
Jeepfanatic
PostPosted: Tue Sep 09, 2008 8:29 pm    Post subject: Reply with quote
sometimes it is the crank position sensor and a new one fixes it. might want to go with a high voltage coil also
Love My Jeep
1998 2 Door 5spd 2wd
Edge Cold Air Intake
Edge Bored Throttle Body
helix Throttle Body Spacer
MSD Coil 8MM Wires
My Old 94 Chirped 3 gear on a hot summer day
One fast Jeep
