Need help new engine won't fire up....
okcjeeper
PostPosted: Mon May 26, 2008 8:12 am    Post subject: Need help new engine won't fire up.... Reply with quote
Ok put a new crate motor in my 91 XJ...The block is from a 94 and is the 4.0. My issue is when I try to start it the motor just turns and turns and never fires up.. Tested the spark and watched the plug spark once and then no more spark after that. So I am hoping someone can point me in the right direction or has experienced this. I also replaced the ignition coil.
c130herc
PostPosted: Thu May 29, 2008 6:54 am    Post subject: Reply with quote
If you have a tach look to see if it bounces while you crank. If it does not bounce or you do not have one go ahead and check to make sure you connected the 2 wires that are mounted to the oil dipstick bracket. If these wires are not connected the computer will not send the pulse trigger voltage to the coil. The bouncing tach is that pulse trigger voltage.
The old CPS thing could cause you problems. Also check to make sure the ground strap on the top back part of the motor is attached
Another thing is yours should be a RENIX system and your motor comes from a non RENIX XJ. There are a couple of things different on the exhaust but those will make it run rough.
Look at this link, it might help.
http://www.lunghd.com/Tech_Articles/Engine/Basic_Sensors_Diagnostics.htm
okcjeeper
PostPosted: Sat May 31, 2008 7:21 pm    Post subject: Reply with quote
Thanks for the reply..got it running..the distributor wasn't indxed properly...Oh and the 91's aren't RENIX models..Smile Thanks again..
