96 Grand Cherokee drive shaft removal
andyj6965
PostPosted: Tue Jun 24, 2008 11:27 am    Post subject: 96 Grand Cherokee drive shaft removal Reply with quote
I have a 96 GC Ltd w/ 5.2L. I need to replace the seal and possibly the pinion bearing on the front differential. What is the bolt size on the u-joint in front of the transfer case? 8mm and 5/16 are too big, 7mm and 9/32 are too small.
If it's ain't broke you ain't riding hard enough!
PostPosted: Tue Jun 24, 2008 11:41 am    Post subject: Re: 96 Grand Cherokee drive shaft removal Reply with quote
I usually use 5/16" at the axle and 8mm at the t-case, front or rear driveshaft.
andyj6965
PostPosted: Tue Jun 24, 2008 5:15 pm    Post subject: Re: 96 Grand Cherokee drive shaft removal Reply with quote
Either of these sizes appear sloppy and when I turn the wrench (box end) the wrench slips. I've tried more then one wrench, even my neighbors wrenches.
egc519mzl
PostPosted: Fri Aug 08, 2008 1:50 pm    Post subject: Reply with quote
I was able to take it out using the open end instead of the box end. Don't forget the blaster or whatever you are using. And just apply quick and not so hard pressures.
94 ZJ Laredo Hunter Green
Bought with broken tcase and leaking radiator. Undrivable condition. My first auto project.
PostPosted: Fri Aug 08, 2008 5:11 pm    Post subject: Reply with quote
heat it up with a propane torch some one might have loctighted it .
andyj6965
PostPosted: Fri Aug 08, 2008 6:23 pm    Post subject: Reply with quote
Yea, it was loctited. I got it off with a visegrip. Thanks.
