Shaking Steering wheel
sermeno
PostPosted: Wed Jun 25, 2008 7:36 pm    Post subject: Shaking Steering wheel Reply with quote
1997 Jeep Grand Cherokee, 5.2L, 2WD, Automatic. The Steering wheel begins to shake violently from side to side, (not up and down), at highway speeds. It continues to do so until the vehicle, (under braking), is almost completely stopped. I have replaced the tires, the hub bearings, the steering stabilizer, the sway bar bushings and links. The upper control arm bushings at both ends have been replaced, and the lower control arm bushings have been replaced at the axle. Does this vehicle have a common problem with the upper or lower ball joints?
sermeno@aol.com
PostPosted: Wed Jun 25, 2008 8:33 pm    Post subject: Reply with quote
Check the track bar at both ends, make sure it's very tight.
