I messed up!!
TMG
PostPosted: Wed Jul 02, 2008 8:43 pm    Post subject: I messed up!! Reply with quote
So I successfully installed my SYE but found that I used the wrong gasket maker and had to pull the transfer case and start over, no big deal. When I split the case again the parts came out too fast and I put it back together wrong, feel pretty dumb now. Problem is when shifter is in 2h case is in 4L, when in 4H case is in N, 4L case is in 4H. Can anyone help. Thanks Embarassed
Jeep_addict
PostPosted: Thu Jul 03, 2008 5:43 am    Post subject: Reply with quote
Sounds like you just need to readjust your shifter linkage.
PostPosted: Thu Jul 03, 2008 7:52 am    Post subject: Reply with quote
Maybe the shift fork is installed wrong?
PostPosted: Thu Jul 03, 2008 9:16 am    Post subject: Reply with quote
X2
Jeep_addict
PostPosted: Thu Jul 03, 2008 5:33 pm    Post subject: Reply with quote
Or maybe you have the shifter lever where it mounts to the transfer case on 180 degrees off.
