mounting 35s on my 85 jeep cherokee!!!!!!!!!!
jeepcherokee85
PostPosted: Sun Jul 27, 2008 6:33 pm    Post subject: mounting 35s on my 85 jeep cherokee!!!!!!!!!! Reply with quote
i have a 1985 jeep cherokee and i have 30" and a 3 inch lift and i just got a really good deal on 4 35x12.50x15 i was wondering after i cut my fenders how much more of a lift would i need to wheel with the 35s??
any comment would help!!
PostPosted: Sun Jul 27, 2008 9:38 pm    Post subject: Re: mounting 35s on my 85 jeep cherokee!!!!!!!!!! Reply with quote
A lot, actually. With 3" of lift and trimming, that's plenty of room to stuff 31's Muddies and MAYBE 32's All Terrains, but not much more than that. 35's are going to require at the bare minimum 5.5" of lift, preferrably something like a long-arm kit (THAT might even be pushing it). There's not a lot of room underneath there with the suspension, and for 35's you are going to need some flex room or you'll bottom out on everything bigger than a pebble.
In addition to that, be aware that you can't take a lot off of the rear fender well due to the close placement of the seam back there. It's only about an inch or so of metal before you hit the side-to-body seam, and that you definitely don't want to cut into.
PostPosted: Sun Jul 27, 2008 9:38 pm    Post subject: Reply with quote
From the sticky at the top of the section:
kacon wrote:
35x12.50"
8" lift - fender trimming will be needed
Note:
- This is with minimal lift needed
- With a combination of aftermarket flares or TJ flares / fender trimming will help to accommodate larger tires for full articulation. (This becomes a factors with mostly 32"+ tires)
http://www.jeephorizons.com/phpbb/viewtopic.php?t=1423
PostPosted: Mon Jul 28, 2008 7:45 am    Post subject: Reply with quote
I have ~8 in my xj and my 36s fit nice. I could stand a bit more trimming, they kinda rub at full turn and flex
I wheeled with a guy on 37s and 5 inches of lift this weekend...
I would add about 2 more inches of lift and trim the hell outta it
PostPosted: Mon Jul 28, 2008 10:21 pm    Post subject: Reply with quote
kacon wrote:
35x12.50"
Note:
That's what I get for not reading it either... Neutral
Danka-shein. Mr. Green
