Battery Not Charging
egc519mzl
PostPosted: Sat Aug 09, 2008 9:41 am    Post subject: Battery Not Charging Reply with quote
Hi, I dismantled my alternator today and I think I found the defective part. I am not sure if it is a resistor or diode. See the blue circle in the second photo. It is only this part that has no continuity. It first reads about 200M ohms and then it would become open. Am I on the right track?
If anyone has done a fix on this before, where can I find and buy this part? Thank you.
And by the way, while I was on it, I would like to replace the PCV but the thing cannot be pulled out easily. Is there a technique of pulling that out without breaking it? It is already broke and the other half is still stuck on the cover.
94 ZJ Laredo Hunter Green
Bought with broken tcase and leaking radiator. Undrivable condition. My first auto project.
kaos
PostPosted: Sat Aug 09, 2008 3:15 pm    Post subject: Reply with quote
It is probably a capacitor (condenser), and, according to your description, in working order.
I may be telling you something you already know, but the diodes should only show continuity in one direction.
Best regards,
Kári
egc519mzl
PostPosted: Sat Aug 09, 2008 5:34 pm    Post subject: Reply with quote
Thank you for the reply. You are correct! I connect a 12 volt house battery and it stored some voltage. So it is a capacitor.
What should I tackle next? Where can I find the voltage regulator? Is it the black thing that's attached to the alternator?
I visually checked the alternator, I didn't see any burn sign. The rotor's terminals read a negligible ohm. As well as the four terminals of the stator. Do you think that would be enough? Or should I turn the rotor and see if it produces an AC on the stator.
PostPosted: Sun Aug 10, 2008 6:04 pm    Post subject: Reply with quote
Voltage reg is built in to the alt..
How do the brushes and the comm look??
