New Noise from the front
mexirican
PostPosted: Tue Aug 12, 2008 12:40 pm    Post subject: New Noise from the front Reply with quote
Every time I put my Cherokee into 4WD, I get a loud popping noise that is comming from right under the seat. I took a look at it today and the u-joints are fine. (Had to change the rear ones already so I know what to look for) There is a little play in the front drive shaft, I dont know if it is supposed to be there. Anyways, I cant use 4WD at all. The noise scares the hell out of me. Any ideas?
PostPosted: Wed Aug 13, 2008 9:31 am    Post subject: Reply with quote
Did you look at the u-joints on the axles, at the wheel joints? How's the fluid in the t-case?
PostPosted: Thu Aug 14, 2008 9:55 pm    Post subject: Reply with quote
what about the cv joint ?
does it do it in 4 low to ?
