My AC?
1999amethyst
PostPosted: Wed Aug 13, 2008 8:32 am    Post subject: My AC? Reply with quote
Hey guys first post, i have a 99 XJ and love it! BUT my AC doesn't work, the air blows out and it has been charged. What are some things i can check that would be easy fixes?
unforgiven
PostPosted: Wed Aug 13, 2008 1:23 pm    Post subject: Reply with quote
welcome!!!
not too sure of yer question.
would you prefer it to SUCK the air in? Mr. Green
perchance a better description of yer issues is in order.
1 sticker !!! lol
1999amethyst
PostPosted: Wed Aug 13, 2008 11:13 pm    Post subject: Reply with quote
I mean when the air comes out of the vent it isn't cold. how do i fix that or what can i check?
PostPosted: Thu Aug 14, 2008 5:54 am    Post subject: Reply with quote
when you turn on the ac the electric fan should kick in , you can hear this .
simultaneously you should hear a "click" this is the ac compressor kicking in .
there could be a leak and your fresh charge has bleed off, but i think i have got you started .
ac compressor should kick in on defrost . there are fuses under the hood and possibly under the dash . and a relay under the hood , swap it for another one in a system you know works . there all the same relays .
write back what you've found .
DavidXJ
PostPosted: Thu Aug 14, 2008 7:17 am    Post subject: Reply with quote
Yah, the first place you have to start is whether or not the AC pump is kicking on, and whether the auxilary electric fan is kicking on with the pump. Once you have established that these are working, then you can move on to the wack load of other things it can be.
1999amethyst
PostPosted: Thu Aug 14, 2008 10:53 am    Post subject: Reply with quote
thx ill check that
1999amethyst
PostPosted: Sun Aug 24, 2008 9:58 pm    Post subject: Reply with quote
Does the car have to be on to check and see if the ac turns on? and what noise does it make? when the cars on and i turn the ac to on it makes a hissing noise for a second and when i turn it off.
99-XJ
