How much it will cost to rebuild the rear differential?
Goto page 1, 2  Next
antibiotics
PostPosted: Thu Aug 21, 2008 6:28 pm    Post subject: How much it will cost to rebuild the rear differential? Reply with quote
Hi folks,
I just got a 1999 cherokee, I6, AWD and automatic at a cheap price. A major issue with this jeep is the clunk noise on the rear end while car is moving.
The garage suggest a rebuilt of the rear diff after a brief diagnosis and want $750 for it. I wonder if this is a reasonable price.
Somebody also suggested me to swap in a new rear diff by myself. I am curious how difficult is this job? Any write-up? What is the best place to get the part.
Thanks.
1999 Cherokee 4WD, I6 and automatic
PostPosted: Fri Aug 22, 2008 5:25 am    Post subject: Re: How much it will cost to rebuild the rear differential? Reply with quote
antibiotics wrote:
Hi folks,
$750 sounds a little high. Labor for a professional gear setup is usually about $250 plus some regional variation and variation from shop labor rates. Then add in parts...and not knowing exactly what's wrong with your rear, it's hard to say what parts are being replaced.
I'd suggest getting a written, itemized estimate and ask so see the damage. If it's something simple like spiders and side gears, then $750 is grossly overpriced. If it requires a full gear setup and all new parts, then $750 isn't too bad but still alittle high IMO.
Thanks.
Find one locally at a salvage yard. www.car-part.com
Installation is as simple as supporting the vehicle, disconnecting the brake lines, parking brake cables, driveshaft, differential breather, ABS sensors if so equipped, and unbolting the u-bolts that hold the axle to the leaf spring. Then slide it out. Installation is the reverse.
PostPosted: Fri Aug 22, 2008 4:13 pm    Post subject: Reply with quote
it will take you a couple hours , don't wreck the brake hose , undo it first .
i can pick up and walk around with the stock jeep diff , so its not that bad .
djgrayxj
PostPosted: Sun Aug 24, 2008 8:50 am    Post subject: Reply with quote
Welcome to the best Jeep XJ Forum
First question what is your level of mechanical ability [fair], work area [flat surfs] and tools [basic]?
If you canít meat the above conditions, get a second opinion. You could have something as simple as a bad u-joint.
Second question has this Jeep been lifted? If it has this might be your problem if it was not done properly.
Let us know if you want to take on this project yourself. If so there is a lot of good info available from many mines.
Tom_TJ_Performance
PostPosted: Tue Aug 26, 2008 8:38 am    Post subject: Reply with quote
my shop also charges $750
PostPosted: Tue Aug 26, 2008 9:28 am    Post subject: Reply with quote
What exactly do you do for $750? Just wondering! Cool
Tom_TJ_Performance
PostPosted: Tue Aug 26, 2008 9:39 am    Post subject: Reply with quote
remove and replace R&P $345.45
gear set $250+
bearing and seal kit $125
gear oil $17.40
gasket $7.50
posi additive $9.63
SPONSORS
NOS Energy Drink | Currie Enterprises | Justice Brothers | F&B Throttle Bodies | Rustys Offroad | Buna Photo
Sato Brothers | V1X.net | T&J Performance Center
PostPosted: Tue Aug 26, 2008 10:56 am    Post subject: Reply with quote
gear set $250+
gear oil $17.40
gasket $7.50
posi additive $9.63
I don't know where you buy your gears, but that's a nice mark-up, especially since you're charging $350 for the setup.
Tom_TJ_Performance
PostPosted: Tue Aug 26, 2008 11:01 am    Post subject: Reply with quote
labor...remember your not just paying us to do it your paying us to do it right
we can get gear sets cheaper but we prefer to use a quality gear set. precision gear
SPONSORS
PostPosted: Tue Aug 26, 2008 11:05 am    Post subject: Reply with quote
I've bought Precision gears before. They aren't that much.
http://www.tellico4x4.com/index.php?manufacturers_id=335&sort=5a&filter_id=1931
Most for a D44 start about $170-180.
Tom_TJ_Performance
PostPosted: Tue Aug 26, 2008 11:18 am    Post subject: Reply with quote
that site is selling at my cost. when you buy in bulk you get a HUGE discount
SPONSORS
PostPosted: Tue Aug 26, 2008 1:33 pm    Post subject: Reply with quote
Last time I did these repairs, I only charged $150 labor. The R&P were only $150. Damn, I'm cutting my own throat! rofl rofl
Tom_TJ_Performance
PostPosted: Tue Aug 26, 2008 2:31 pm    Post subject: Reply with quote
i dont want to get into a pissing match over this. i dont think it will get either of us anywhere. this is our price do do this job. we are actually cheaper that some of the other shops around. we did do a lot of research before we set the price and every time we get our prices increased we have to raise our price. i dont know how much you can charge to do this in Massachusetts or how many people you have working for you or what your overhead is. so i wont say your to low or high in your area. as you know doing business in southern california is very expensive especially in orange county.
SPONSORS
PostPosted: Tue Aug 26, 2008 3:20 pm    Post subject: Reply with quote
Maybe you should find a new supplier who'll give you better deals then??
Tom_TJ_Performance
PostPosted: Tue Aug 26, 2008 3:30 pm    Post subject: Reply with quote
we buy direct 1/2 hour to drive there.
SPONSORS
Goto page 1, 2  Next
Page 1 of 2
