High Capacity Transmission Oil Pan
Muckaneer
PostPosted: Mon Aug 25, 2008 5:07 pm    Post subject: High Capacity Transmission Oil Pan Reply with quote
I have a minor leak in my transmission gasket. So I thought I would look into one of these since the pan could be coming off to fix it. Any opinions?
http://www.quadratec.com/products/12518_71.htm
2009 JK Daisy
Muckaneer #1
John OBrien
PostPosted: Mon Jan 26, 2009 10:24 am    Post subject: Reply with quote
I suppose it would depend on what you do with your Jeep. If you're at odd angles then it might do some good but if you're just a driver or off roader w/o the angles you might be better served spending the money on an auxiliary cooler to keep temps down. That pan looks like a rock crawler modification.
I can resist anything but temptation!
