What 5 SPEED Trans lube ?
cowboy
PostPosted: Thu Sep 11, 2008 6:07 pm    Post subject: What 5 SPEED Trans lube ? Reply with quote
Another Question, I did a search, but could not find what to use as lube for the NV3550 5 speed tranny, another member asked the same Question a long time ago but no answer. I know the owners manual states mopar trans. lubricate, dealers # P/N 04874464, but surely there is something else out there that will be just as good ,that you don't have to locate a dealer every time you want to, or need to change ,thanks for the help !!
________
B9 Scrambler
kirkwood007
PostPosted: Fri Sep 12, 2008 4:59 am    Post subject: Reply with quote
Edit: I checked with the lab and they said that we don't make a lube to cover that transmission. Sorry. I even asked if there was another company that makes a fluid for it and there is not. Dealer ONLY! He yelled at me.
Stock 97 TJ 31x10.50's and a fixed TCase,
cracked exhaust and an engine oil leak.
hutchman
Captain Kirk
Captain Kirk
PostPosted: Fri Sep 12, 2008 6:09 am    Post subject: Reply with quote
Here is a discussion on Pirate with some info......
http://www.pirate4x4.com/forum/showthread.php?t=364226
A little more info......
http://www.jeeps-offroad.com/archive/index.php/t-17625.html
cowboy
PostPosted: Sat Sep 13, 2008 6:22 pm    Post subject: Reply with quote
Thanks Guys, and hutchman, those links were great and now will be looking for Pennsoil synchromesh and a 17mm allen !! thanks again
________
Fourth-generation Camaro
