Bubble power steering
deadmanrompjng
PostPosted: Mon Aug 02, 2004 7:54 pm    Post subject: Bubble power steering Reply with quote
Alright I have a 90 xj that has been leaking psfluid since i bought it. A couple of weeks agoit started to grone,low fluid ocourse, no it had plenty of fluid but it was all foamy.So on the safe side i replaced the pump,pulley (cuz i broke it) and the hoses and the damn thing is still doing it anyone know why
Thanks
Jonathan Mac Dowell
D.T.R Finger
PostPosted: Mon Aug 02, 2004 8:02 pm    Post subject: Reply with quote
If it's foamy but the level is normal, you probably have a leak somewhere that's sucking air into the system. I'd check that everything is torqued and all your low pressure lines are properly sealed. Is anything still leaking anywhere?
PostPosted: Tue Aug 03, 2004 6:52 pm    Post subject: Reply with quote
Is the fluid just foamy now? Or is it still groaning too? Like Troy said, if it's still foamy, air is getting in. Those hoses can be a bitch to get sealed up right sometimes...that's the first thing I'd check.
