cracked head
provo
PostPosted: Fri Jan 02, 2009 2:10 pm    Post subject: cracked head Reply with quote
ok i thought it was my freeze plugs when i went to replace them i noticed the actual engine was cracked shock is there ANY way to fix this besided getting a new engine?? the crack is right above the freeze plugs. i really cant afford a new engine right now. please help
-dan-
FARMER
PostPosted: Fri Jan 02, 2009 4:46 pm    Post subject: Reply with quote
Many years ago a buddy had a Dodge Dart with a slant 6 in it, he "repaired" a cracked block with JB WELD, it would hold for about 4 months then he'd redo it, he drve it about 3 years like that. He ran with the radiator cap loose to prevent the pressure from reopning the crack.
kaos
PostPosted: Sun Jan 04, 2009 12:52 pm    Post subject: Reply with quote
What do our resident experts say about welding the crack? I'm not a welder, and from what I have heard welding cast iron is a pain, but I have also heard that it is possible, given the right materials. I guess it might depend on the location of the crack whether this is an option.
Regards,
Kári
PostPosted: Sun Jan 04, 2009 4:05 pm    Post subject: Reply with quote
I'd be looking at a another engine block.
hutchman
Captain Kirk
Captain Kirk
PostPosted: Sun Jan 04, 2009 10:14 pm    Post subject: Reply with quote
ehirner is correct, a new block is the best answer. However, several years ago a good friend of mine did not get the block in his drag boat drained before cold weather and it cracked the water jacket. We took a grinder and opened up the crack slightly to get a good surface for the JB weld to adhere to. We then applied JB weld to the crack as directed on the package and let it cure for a week before putting water back in. This repair held up for 3 or 4 years and as far as I know is still holding.
One caution..........do not grind completely through the block or you will have to buy a new one. Only grind the surface to get down to fresh metal.
FWIW.......
IBTJn
PostPosted: Sun Jan 04, 2009 11:02 pm    Post subject: Reply with quote
Your title says "Cracked Head" and you are saying now it's the block? I'm confused. ???
If it's the head you should be able to replace it (either used and resurfaced or new). If it's the block, then what Hutch said.
Wink
provo
PostPosted: Mon Jan 05, 2009 3:54 pm    Post subject: Reply with quote
yea its the block. my buddy found a place that sells engines for me (actually it was for his cobra the timing just worked out for me) they said they have the jeep 4.0 brand new with a three year 100,000 mile warranty for $2300 delivered so i thinking that wouldnt be to bad of a deal, as long as i can find somebody to install it for relatively cheap. thanks for the help
