2.5" ABS????
wml52@mhcable.com
PostPosted: Thu Jan 29, 2009 7:40 am    Post subject: 2.5" ABS???? Reply with quote
Does anyone know where I can purchase 2.5 ABS pipe and fittings? Im looking to fabricate a snorkel similar to the one K9 posted but Im having a heard time finding ABS pipe in 2.5 size. I live in the Northeast and can only find 2 and dont think 2 will give me adequate airflow. Any help would be greatly appreciated.
Thanks,
Bill
PostPosted: Thu Jan 29, 2009 10:40 am    Post subject: Reply with quote
Check with a plumbing supply house and one post is sufficient.
wml52@mhcable.com
PostPosted: Thu Jan 29, 2009 1:06 pm    Post subject: Reply with quote
The reason for the post was beacuse I could not find 2.5" ABS locally as stated in my post.
The reason for multiple post in different for forums was a simple one. I thought someone from another forum may have the answer, I would not read JK forum posts if I own a TJ, nor would I expect someone who owns a JK to read posts about TJ's. But thanks for the reply.
PostPosted: Fri Jan 30, 2009 1:31 am    Post subject: Reply with quote
I understand you can't find it locally which is why I recommended that you check with a plumbing supply house. Have you checked there?
wml52@mhcable.com
PostPosted: Fri Jan 30, 2009 7:39 am    Post subject: Reply with quote
I've checked with several large plumbing supply houses and distributors in the Northeast but apparently I'm finding that 2.5" ABS is a rather odd size and no one seems to stock it. I can get and would use 2" ABS but thought it might be too restrictive and the 3" ABS is a little too large for my application.
I wanted to use ABS because of its properties and relatively low cost but I'm forced to re-think the materials used. I was going to look into using 2.5" aluminum exhaust tube, a bit more $$$$ but at least I can get it in a 2.5" diameter. It just would have been easier and less expencive to use the ABS, no welding, no painting involved.
Thanks,
Bill
BLACK&TAN
PostPosted: Fri Jan 30, 2009 2:00 pm    Post subject: Reply with quote
Most of the supply houses will order you material for you if they dont have it in stock. Ask em
