stretched cj
Destefano027
PostPosted: Fri Feb 20, 2009 9:14 pm    Post subject: stretched cj Reply with quote
im looking to stretch my cj 7 in the rear i have a yj 4" skyjacker spring on it now what is the best spring to use to use i was lookin to use cherokee spring but i don't no what size lift i would need to keep the same hight any advice would help
Greg G
PostPosted: Wed Feb 25, 2009 12:04 pm    Post subject: Reply with quote
Man you better tell us a little bit about the Jeep.
Greg G
http://powerandplay.com
1997 ZJ Grand Cherokee - 3" lift - BFG's
1992 XJ Cherokee - 4" lift - BFG's
1980 CJ-7 - 1 Ton way to much to list
1983 SJ Grand Cherokee
Destefano027
PostPosted: Wed Feb 25, 2009 4:45 pm    Post subject: Reply with quote
not sure what else you need but Chevy 350 t-18 full width dana 60 SOA 1.5 shackle list 2 in body lift 42x15x15 tsl yj tub tube fenders full cage tired into frame hope this helps out some
erslll
PostPosted: Fri Mar 06, 2009 12:12 am    Post subject: Reply with quote
You are currently running 4" springs SOA plus a body lift and a shackle lift? Shocked
Anyway, I would guess that the lift will be about the same between the YJ springs and the XJ springs. You will have to move your shackle mount back to fit the XJ spring.
Destefano027
PostPosted: Sat Mar 07, 2009 9:31 pm    Post subject: Reply with quote
so a sotck xj spring will give me the same amount of lift as a 4" lift spring?????
i no i will have to move the rear spring mount
erslll
PostPosted: Sun Mar 08, 2009 1:22 am    Post subject: Reply with quote
What I am saying is that a 4" YJ spring is gonig to give you about the same lift as a 4" XJ spring, whether it is SOA or SUA. Either way, if you are using a 4" lift spring in the stock type mounts, it is going to be very tall.
unforgiven
PostPosted: Sun Mar 08, 2009 2:50 am    Post subject: Reply with quote
but, stock xj springs seem very weak. have a tendency to arc the wrong way after awhile, or just flatten out.
if your planning an aftermarket spring, then that would likely be fine.
1 sticker !!! lol
Destefano027
PostPosted: Sun Mar 08, 2009 7:31 am    Post subject: Reply with quote
ok i get what you mean i just miss understood you
