| Author |
Message |
KennyG Member
Posted: Sun Apr 26, 2009 4:22 pm Post subject: 4" rough country lift |
| I just got back into the Jeep scene. I had a few in the early '90s but just got a 2005 unlimited. It came with a 4" rough country lift and 33's. Is this a descent quality lift as I know nothing about lifts? The selling point was it only had 25K for miles and was very clean. If I am correct, this is a TJ right? I won't be doing much for serious off-roading, but will need to do a little for hunting. |
| Back to top |
KennyG Member
Posted: Sun Apr 26, 2009 6:47 pm Post subject: |
| OK, I figured some of this out by reading old posts. Next I'm going to see how accurate the speedo is with the lift and big tires. I can just compare the speedo to a gps. |
| Back to top |
Orangeamc13 Got Rev Limiter?
Joined: 20 Feb 2006 Location: East Springfield, Massachusetts - U.S.A.
Posted: Mon Apr 27, 2009 6:57 am Post subject: |
Welcome!
Yes, your Jeep is a TJ. With only 25k, you must've gotten yourself a nice Jeep! Post up some pics. _________________
| Back to top |
bubbaedc Member
Posted: Sat May 16, 2009 4:29 pm Post subject: |
several ppl in my local club have the rough country 4" lift including me, for the money it is an awesome lift, i have so much articulation now, i went from 30" tires to 32"s and the speedo is still the same, it shouldnt change that much until you re gear _________________ '98 TJ
dana 60/44 combo
| Back to top |
ehirner Moderator
Posted: Sun May 17, 2009 2:23 pm Post subject: |
| bubbaedc wrote: | | several ppl in my local club have the rough country 4" lift including me, for the money it is an awesome lift, i have so much articulation now, i went from 30" tires to 32"s and the speedo is still the same, it shouldnt change that much until you re gear |
The speedo is not the same unless you've got really small 32s. _________________ 04 Unlimited |
| Back to top |
bubbaedc Member
Posted: Mon May 18, 2009 10:50 am Post subject: |
every police speed thing on the side of the road ive driven by has been within 1MPH of what my dash speedo says... _________________ '98 TJ
dana 60/44 combo
| Back to top |
ehirner Moderator
Posted: Mon May 18, 2009 1:08 pm Post subject: |
| bubbaedc wrote: | | every police speed thing on the side of the road ive driven by has been within 1MPH of what my dash speedo says... |
Like I said, unless you've got small 32s, and they do exist more commonly than you'd think, there's no way it is the same as it was with 30" tires.
I'll do some math for you.
30x9.50 BFG ATs have an overall diameter of 29.5". 32x11.5 BFG ATs have an overall diameter of 31.7" per BFG's website. For each revolution of the 30s, you travel roughly 92". For each revolution of the 32s, you travel roughly 100". That's about a 9% increase and would mean your speedo would be off by 9%. For the sake of easier math, let's say 10%.
At 30, you'd really be going 33. At 50, real speed 55. At 65, real speed ~72. At 75, real speed ~83. _________________ 04 Unlimited
| Back to top |
kaos Member
Posted: Mon May 18, 2009 1:25 pm Post subject: |
Speedometers are usually calibrated from the factory to show 3-5 MPH higher than true speed, given original size tires. Thus, moderate increase in tire size would tend to make them more accurate, at least in a certain speed range. IME with both the XJ and The ZJ the manufacturing error was absolute, that is, with original size tires, the speedo showed about 5 km/h too high, whether I was driving at 30 or 90 km/h. (With some other manufacturers this error is proportional.) The error caused by the increase in tire size is always proportional.
Thus, with the speedo showing 5 kph too high, and with tires with 5% larger diameter than the originals, the speedo would end up spot on at 100 km/h, but still be reading too high at lower speeds, and too low at higher.
Regards,
Kári. |
| Back to top |
bubbaedc Member
Posted: Wed May 20, 2009 6:30 am Post subject: |
ahh ok i understand now _________________ '98 TJ
dana 60/44 combo
| Back to top |
r6less Member
Posted: Sun Nov 08, 2009 8:59 pm Post subject: |
| I believe the Unlimited Jeeps are LJs. |
| Back to top |
Posted: Mon Nov 09, 2009 8:18 am Post subject: |
| r6less wrote: | | I believe the Unlimited Jeeps are LJs. |
Yes, you're right! I missed the Unlimited part. _________________
| Back to top |
