2001 Jeep Cherokee "no bus 5" message?
jr2212
PostPosted: Thu Jun 25, 2009 8:02 pm    Post subject: 2001 Jeep Cherokee "no bus 5" message? Reply with quote
Started the Jeep today, no temp, oil pressure, or voltmeter gauges. The speed, tach, and gas gauges are also out. My engine warning light is on and I have the message "no bus 5" on the odometer.Read the post "Bombed out Gauges" from 12/4/06 and Phantoms reply. There is a lot of talk about loose ground connections on the cluster causing these problems. My problem with the ground solution is as Phantom stated " the GND ground circuit services the temp, oil pressure and voltmeter gauges while the LGD services the speed, tach and and feul gauges", I have failure in all areas at the same time, what are the chances of both grounds coming loose at the same time????
Where should I go from here????
When it comes to mechanical stuff failure is always an option!
