Ham Antenna Install on '05 Cherokee
sqrl18
PostPosted: Wed Jul 29, 2009 9:05 am    Post subject: Ham Antenna Install on '05 Cherokee Reply with quote
Hi,
I need to install an antenna for a HAM radio. I thought I would have to put a hole in the firewall, as the cable is delicate. I saw a post for AMP cable, but the model is older than mine and the '05 does not have any wires going through the door jam. Has anyone done this, or can you advise if there is an existing opening somewhere that I can fish the cable through? The connector is about 3/4", so I'll need that much space. Or, can someone walk me through how to put a hole in the firewall? Dumb it up, because I'm a girl - literally. Thanks!
PostPosted: Wed Jul 29, 2009 10:53 am    Post subject: Reply with quote
Are you sure it's an '05 Cherokee?
sqrl18
PostPosted: Wed Jul 29, 2009 11:22 am    Post subject: Reply with quote
Sorry - my bad. '5 grand cherokee. girl thing kicking in again Embarassed Thanks for catching that!
IBTJn
PostPosted: Wed Jul 29, 2009 4:17 pm    Post subject: Re: Ham Antenna Install on '05 Cherokee Reply with quote
sqrl18 wrote:
Hi,
There might be a rubber grommet on the firewall if you look closely. I'm not sure on the Grands though. But most Chrysler products had them...especially Jeeps. On my Dodge truck I simply drilled a 1/4" hole in the firewall because I couldn't quite get to the grommet. But I would have never considered drilling a 3/4" hole simply to fit the PL-259 connector. It's much cleaner to cut off the connector, fish the coax through, and install a new PL-259 connector. On the Jeeps I used either an existing grommet or used a different mount.
So it would be helpful to know what ham antenna (and mount if any) you are trying to use. Some can be taken apart so you only have to fish through the size of the coax. Some cannot though...like many magnet mounts.
Sorry, no dumbing this down. I know too many lady ham operators who would be offended at such a gesture. rofl
Wink
hutchman
Captain Kirk
Captain Kirk
PostPosted: Wed Jul 29, 2009 7:38 pm    Post subject: Reply with quote
IBTJn is the man for anything connect with ham radio!
