throttle body size
provo
PostPosted: Fri Oct 30, 2009 10:19 pm    Post subject: throttle body size Reply with quote
how large is the stock throttle body on an 01 wrangler with a 4.0? i ask because i need a new one and am thinking about going larger but would like to know what is the norm. thanks
PostPosted: Sat Oct 31, 2009 7:39 am    Post subject: Reply with quote
I think it's about 54mm.
hutchman
Captain Kirk
Captain Kirk
PostPosted: Sun Nov 01, 2009 8:53 am    Post subject: Reply with quote
Why do you want a larger TB? I always ask because unless you already have 5.38s and turn the engine 5 grand +, there just doesn't seem to be a reason for a larger TB.
If you are running a stock drive train, you want torque.......and torque is produced by increasing volumetric efficiency. At low engine speed that means keeping the incoming mixture at the highest velocity possible. High mixture velocity is attained be smaller diameter intake and exhaust not larger. There was a guy named Bernoulli who figured this out along time ago.
Stock is good for stock..........
neon22
PostPosted: Thu Nov 05, 2009 8:09 pm    Post subject: Reply with quote
i thought the stock tb was 60mm for the 4.0l. you can probably just call your jeep dealer and ask them what the size is but im pretty sure it is 60mm. but dont quote me on this
PostPosted: Fri Nov 06, 2009 7:28 am    Post subject: Reply with quote
The top of the tb is 60mm, but the bottom is narrower.
http://go.jeep-xj.info/HowtoTBboring.htm
