98 TJ PCM swap
Darbster
PostPosted: Sun Dec 06, 2009 2:03 pm    Post subject: 98 TJ PCM swap Reply with quote
Can you use the wiring harness, ECU and PCM from a 97 XJ in a 98 TJ?
Texas Gypse
PostPosted: Tue Dec 08, 2009 12:48 pm    Post subject: Reply with quote
Hmm Im not 100% sure if it works perfect or not but, I do have a friend how did the same thing and went to a local junk/scrap-yard to get the parts he need. He ended up only spending $25.
Just be sure to get it off of a 4wd model. Because I do know that if you take it off of a 2wd model you tranny will not work right.
Texas Gypsy
31'' BFGs, American Racing Rims- Majave, Kenwood Headunit, MTX Thunder 6 1/4'' Rollbar Speakers, Two Kicker L5 10'' Subwoofers in ProBox, B&M Shift Kit, Front Spartan Locker!
