| Author |
Message |
Jason87 Member
Posted: Mon Dec 14, 2009 1:55 pm Post subject: 03 renegade |
so im looking to buy a 03 renegade but it has 130k miles, is this a deal breaker, what repairs should i see coming, also where can i get the thicker roof rack that matches the light bar if i do get it?
thanks alot |
| Back to top |
meduncan Member
Posted: Fri Jan 22, 2010 5:02 pm Post subject: |
I purchased an '03 Renegade just this summer and it had 117K miles. The emergency brake wouldn't hold the Jeep still when the Jeep was in drive even though I wasn't touching the gas. Beyond that, the only things that I would classify as a non-routine maintenance was that I had to replace the valve cover gaskets and the left upper control arm. The control arm's rubber boot was shredded so the ball joint wouldn't have lasted much longer.
In the routine maintenance side of things I replaced the rotors, pads, plugs, coils, air filter, all the fluids were changed, and the battery was replaced. Those were really of my own choice though as I like to start "clean" with a used vehicle.
Every vehicle is different so take my entire list with a grain of salt. The Liberty is a great Jeep and if you're intersted in a used one I would suggest that before you purchase it you should take it over to a Goodyear shop and have them do a used car inspection. It'll probably cost around $50 - $75, but it will give you piece of mind on your purchase decision. _________________ 2003 KJ Renegade
Viair onboard air system, Skid Row skids, 2.5" lift (misc parts), Powertrax No-Slip, ARB front bumper, Jeepin Al's A-Arms, & Rugged Ridge 10.5K winch
**Prior Jeeps**
Wranglers 1989, 1998, 2005
Liberty's 2004 Renegade |
| Back to top |
