YJ 92 4.0 Starting Problem
YJ JIM
PostPosted: Wed Dec 16, 2009 10:30 pm    Post subject: YJ 92 4.0 Starting Problem Reply with quote
My 92 YJ 4.0 with auto/4x4 will not start without holding the throttle down a little, thats hot or cold. It will not idle until it warms up and then it idles and runs fine. Does that sound like the Throttle Position Sensor is bad or what.
Any advice with this would be much appreciated. Very Happy Very Happy
Thank you
YJ JIM
GospelJeep
PostPosted: Sun May 09, 2010 6:14 pm    Post subject: Reply with quote
Still have a problem? TPS was my first thought too.
"Go cheap - at all costs!" -Elliott Parfitt
YJ JIM
PostPosted: Mon May 10, 2010 6:27 am    Post subject: Reply with quote
Thanks GospelJeep, yes I still have this problem. It has not changed and I have not had a chance to check it out. It still runs good after it starts and I am just putting off fixing it. When a smog test is do I'll likely have to fix it.
Thanks again
YJ JIM
