Malfunction Indicator Lamp
taz
PostPosted: Sat Feb 13, 2010 8:43 am    Post subject: Malfunction Indicator Lamp Reply with quote
My 2005 Jeep Rubicon failed emission inspections because the mil failed to come on when you turn the key to the on position what could cause the light not to function?
PostPosted: Sat Feb 13, 2010 4:54 pm    Post subject: Reply with quote
The bulb might be out. If the light doesn't come on when you start it, I doubt that it would if there was a code.
PostPosted: Tue Feb 16, 2010 5:37 am    Post subject: Reply with quote
Wow...talk about strict inspection. I'd check the bulb as well. You can remove the instrument cluster and access the bulbs from the back.
