Hmm, possible transmission swap?
tobiism
PostPosted: Sun Feb 14, 2010 5:37 pm    Post subject: Hmm, possible transmission swap? Reply with quote
I have a '94 Grand Cherokee I6 with 4WD. The tranny quit on my wife last night, just totally slipped with no acceleration. Then it made a bit of a whiney noise when she tried to shift it into different gears. I pulled the pan from the tranny to check the filter and I saved all the tranny fluid that came out because it looked okay and don't want to refill with new oil after all of the problems I've heard about. When I took the filter to Autozone they said it was the filter for a V8 Jeep. This is the filter that came out.
Which model tranny is this filter from?
I had assumed that this Jeep had the 42RE.
Anyone know?
Thanks
Matt
ZJ_Ras
PostPosted: Sun Feb 14, 2010 7:38 pm    Post subject: Reply with quote
That sure looks like the same filter my 95 GC 5.2 V8 uses.
Jon
'95 ZJ Orvis Edition 5.2L V8 with 210K+ miles Featuring a 2" Budget Boost with Skyjacker Hydro Shocks, 242 T-case swap, JKS Quicker Disconnects, 30x9.5s, cold air intake, throttle body spacer, 136A alternator and a DIY roof rack spare carrier.
PostPosted: Mon Feb 15, 2010 11:40 am    Post subject: Reply with quote
I'm pretty sure the 42re (4.0) uses the same filter as the 46rh (5.2). That looks right to me. Autozone was probably looking at the AW4 filter when comparing. Post a pic of the tranny pan if you can.
