"Loose" front end??
tomynoks
PostPosted: Mon Mar 29, 2010 10:17 pm    Post subject: "Loose" front end?? Reply with quote
My front axle feels like it is loose... what I mean is that when I put it in reverse....go slow and hit brakes, it feels like the axle slips a little..like physically moves forward.. also, on bumpy roads it kind of clunks around a little. I have newer Rubicon LCAs... could this be my stock UCAs?? What else could it possibly be? Thanks guys!
'99 XJ Sport
AirAid Intake
PowerAid Throttle body spacer
RE6030 3.5"
1" T-case drop
31x10.5x15 BFG AT KO's
eggdashure
PostPosted: Thu Aug 12, 2010 10:31 pm    Post subject: Reply with quote
I run WJ lower arms and stock Cherokee uppers currently. The WJ LCA's are great, but the upper arms developed a clunk on the drivers side. I pulled the arm off, replaced the bushing and all was great...for about a month. Then it started squeaking and clunking again. I need some CA Drop Brackets to straighten everything up, I suspect that will help with the clunks too. Just my thoughts. Mr. Green
The Jeep Happens Guy
PostPosted: Fri Sep 24, 2010 5:06 am    Post subject: Reply with quote
Try checking your track bar mount on the unibody frame rail. Mine will loosen from time to time. Causes a clunking or popping when it gets loose. Mostly when I'm backing up and turning at the same time. Hope this helps
"Life is not a practice run."
