dome light?
sdoroski12
PostPosted: Fri Apr 16, 2010 7:55 am    Post subject: dome light? Reply with quote
I got in this morning and the headlights on or key in ignition chime is binging away and there is not enough juice to turn the engine. Problem is the key was in my hand and the headlights were off? The dome light was on but the doors were closed. Is there a seperate switch for the dome light? I have never used it directly. It comes on when I open the door and it usually goes off when I close them. If there was a switch I didn't directly turn it on. Any ideas because the doors and tailgate were definately closed all last night and I could hear the chime binging away through the closed doors?
FARMER
PostPosted: Fri Apr 16, 2010 9:37 am    Post subject: Reply with quote
Try turning the headlight switch.
TJ Apex
PostPosted: Sat Apr 17, 2010 9:41 am    Post subject: Reply with quote
There are two rotating switches on the turn signal lever. The out board switch controls the headlights, the in board switch controls the dash dimmer and the dome light. As you rotate the switch, you turn the dash dimmer to full bright, there is a secondary position for the dome light, and if the switch is left on, the light will remain on, so be careful.
2002 Wrangler Apex
02' Apex Edition,
2" BB, 31" BFG AT's
