1997 Cherokke Country differential: limited slip?
Joh's jeep
PostPosted: Sat Apr 24, 2010 11:15 am    Post subject: 1997 Cherokke Country differential: limited slip? Reply with quote
Hello,
I have a 1997 Cherokee Country 4.0, with factory installed Tow package and "Country Package 26H" (whatever this means?).
My question: does anyone know if this includes the limited slip rear differential? I do have the original invoice, and it does not say so, but I though it might be part of the tow package. I need to know, because I want to change the differential oil, and I wonder whether or not to add the limited slip additive.
Thank you in advance for the help!
Johannes
Highlander
PostPosted: Sat Apr 24, 2010 11:48 pm    Post subject: Reply with quote
My 97 has the Tow Package but no Limited slip.
Jack both back wheels off the ground at the same time.
With engine Off, turn one wheel and see if the other side turns the same way, if so you have Limited Slip, if they rotate in opisite directions,
you don't.
Lenny
PostPosted: Sun Jul 11, 2010 12:38 pm    Post subject: Reply with quote
Does your model have the Selec-Trak gearbox??? if so then you should use the additive. Also the diff oil to use is different to the normal spec if the tow pack is fitted you need to use 75W-140 in the back axle and the ususal 75W-90 in the front.
