Vacuum help needed
Sykopro
PostPosted: Thu Apr 29, 2010 12:06 pm    Post subject: Vacuum help needed Reply with quote
I need to get some pictures of where all the vacuum lines go on a 92 4.0. I have trie searching the forums but couldn't find anything. The engine starts up and once it gets back down to normal idle RPM's it cuts off. I have been told by a few mechanis friends that this sounds like a vacuum issue, an I discovered a couple of missing lines.
'92 YJ 4.0 and AX15 coupled to the NP231, 5" BDS Lift, Pro Comp Steering Stabilizer, Pro Comp A/T tires on Pro Comp Rims, SYE W/Tom Woods Custom Drive Shaft.
YJ JIM
PostPosted: Mon May 10, 2010 6:55 am    Post subject: Reply with quote
Hi Sykopro
If you are still having a vacuum line problem, you can go to CARB and they can give you a printout of your vehicle's vacuum line schematic.
YJ JIM
