Axle track length
gsune
PostPosted: Sun Jun 20, 2010 2:25 pm    Post subject: Axle track length Reply with quote
HI, i have a cherokee classic 2000
i will swap the rear axle. iīll put a dana 60 narrored.
the question is: whatīs the cherokeeīs factory length?
the specifications says itīs 58" track but from where to where?
Thanks.
Cherokee classic 2000, 33", long arms, dana 300 flipped, snorkel, 8274 modified winch, 62 mm throttle body, 24.8 P/h injectors, round intake whith 1998 4.0 engine. dana 44īs, bronze disk clutch, ax15, 3" rear drive shaft whith flanges...
gsune
PostPosted: Sun Jun 20, 2010 2:29 pm    Post subject: image Reply with quote
http://img529.imageshack.us/img529/4785/axlewide.jpg
PostPosted: Sun Jun 20, 2010 4:57 pm    Post subject: Reply with quote
They are usually measured from WMS to WMS.
WMS=Wheel Mounting Surface
gsune
PostPosted: Sun Jun 20, 2010 5:04 pm    Post subject: Reply with quote
So?
Iīm from venezuela,i speaks spanish, so please explain it to me like a child.
thanks
kaos
PostPosted: Mon Jun 21, 2010 12:30 am    Post subject: Reply with quote
The surface the wheel sits on when the wheel is mounted. For an axle with drum brakes, this is the outside of the brake drum. In other words, just about where you put the lines in your picture.
Best regards,
Kári.
gsune
PostPosted: Mon Jun 21, 2010 4:17 am    Post subject: Reply with quote
ok thanks
but what is the cherokee xj 2000 dana 44 rear and front axle measure?
are both of equal distance?
which is stronger axle: ford van dana 60 or explorer 8.8 ?
what is the measure of the explorer 8.8 axle?
thaks
PostPosted: Mon Jun 21, 2010 8:24 am    Post subject: Reply with quote
Stock XJ axles are 60" WMS to WMS. XJ's came with a D44 rear in 87-89, they don't have stock front D44's. If your Jeep has 44's, they are not stock.
The D60 is stronger than the 8.8. A lot of 60's are 31 spline, but the ford vans can have the 35 spline.
The 8.8 measures 58 1/4" WMS to WMS.
gsune
PostPosted: Mon Jun 21, 2010 6:00 pm    Post subject: Reply with quote
my cherokee classic 2000 has a stock front dana 44 axle. reverse cut
in venezuela all cherokees xj from 1992 to 2001 have dana 44 in front and rear axle.
in fact we have a dana factory in venezuela (DANAVEN)
thanks for the information about the measure.
DavidXJ
PostPosted: Mon Jul 12, 2010 11:27 am    Post subject: Reply with quote
Porque los otros paises siempre tienen los partes mejores que los Estados Unidos?
gsune
PostPosted: Mon Jul 12, 2010 1:54 pm    Post subject: Reply with quote
Eso no es verdad. aqui llegan los vehiculos sin muchos accesorios que traen en USA, por ejemplo los frenos ABS...
Saludos
DavidXJ
PostPosted: Mon Jul 12, 2010 2:03 pm    Post subject: Reply with quote
I find it strange when car companies do things like that... do they think we wouldn't want to pay for Dana44 axles on Cherokees or that Venezuela wouldn't want ABS brakes on their Cherokees?
On that same line, how come you can get fries with your KFC in Canada, but not the awesome bisquits and mashed potatoes.
Sorry for the tangent. It's cool to see people wheeling in other parts of the world.
