No spark, need help if you can
Grindgearz
PostPosted: Mon Jul 12, 2010 9:47 pm    Post subject: No spark, need help if you can Reply with quote
I was driving down the freeway the other day when i lost throttle response and it started to backfire. when i stoped on the shoulder it died and then took a few tries to start again and it even dieseled for a sec. once i got to crusing speed again it repeted the last episode. this time i had to get towed. no engine warning light but i did try to pull codes but i couldn't get it to flash. on off 3 times in 5 sec. rite? i did find that there is no spark to the plugs, but there was spark leaving the coil and plenty of it. i tested the coil its good. i looked inside the cap and checked the rotor but it all looked fine just a little corrosion i just tuned her up in November. timing chain? pick-up coil? control module? poke
95 ZJ 5.2l, k&n, exhuast via kolak, helper air springs, and some other doodads.
PostPosted: Tue Jul 20, 2010 7:46 am    Post subject: Reply with quote
Distributor pickup or new distributor would be what I would look into next
good luck
PostPosted: Wed Aug 18, 2010 5:08 pm    Post subject: Reply with quote
Might want to try the Crank position sensor as well...
