Starter 93 cherokee
Spiker82
PostPosted: Wed Aug 18, 2010 11:25 am    Post subject: Starter 93 cherokee Reply with quote
Hi need help with replacing a starter on a 93 jeep cherokee.
Any tips on tools or tech info woulh help.
The problem is that a few days ago the jeep wouldnt start.
Had good light and dash lights. was told to check all connection so I replaced the battery lugs and cleaned the connections to the starter.
Started up great for 3 days. Today it wouldnt start again all electrical items worked. Took a hmmer and tapped the starter a few times and it started right up put a meter on the battery putting back 14 v am I reight to think its the starter. Any info would be great thanks Mike
Hello
PostPosted: Fri Aug 20, 2010 8:58 am    Post subject: Reply with quote
Disconnect the battery. Remove the two wires attached to the starter. Remove the two bolts holding the starter in place. Installation is the reverse of this. Mr. Green
PostPosted: Mon Aug 23, 2010 9:20 am    Post subject: Reply with quote
Hey Mike
Is this for a Grand Cherokee or Cherokee?
