ZJ WJ switch
jmcraven
PostPosted: Wed Dec 22, 2010 10:01 am    Post subject: ZJ WJ switch Reply with quote
I have a 97 Jeep Grand Cherokee ZJ and need to switch some parts around from a 00 WJ... What I need to change is the front and rear ends both Jeeps have Dana 30 fronts and Dana 35 rears both have 42 RE transmissions the 00 has a 242 transfer case and the 97 has a 249 transfer case... My question is will the front and rear ends be a simple swap being there is a diffrent code ZJ to WJ.... the 2000 is the donor in this project, as it was in a crash 2 months ago
Thank you in advance to anyone that can answer this for me
PostPosted: Wed Dec 22, 2010 8:35 pm    Post subject: Reply with quote
The axles won't work without modifications.
jmcraven
PostPosted: Thu Dec 23, 2010 6:19 am    Post subject: Reply with quote
Thanks for the reply Orangeamc13 That makes it a lot easier. I have tried looking all over ther place online for ansewrs to that, even calling the Jeep dealiers around here .... I did fine two axels out of a 94 V8 with 373 gears for 100 bucks fingers are crossed that they will fit with no problems as everthing looks the same....
