trouble with new engine
x-tatik
PostPosted: Mon Aug 02, 2004 11:04 am    Post subject: trouble with new engine Reply with quote
I recently installed a newly rebuilt 2.5L EFI 4cyl. into my 1990 YJ.
The problem is it dogs it pretty bad going up hills (no power) and also on warm starts it acts as if it is going to die then revs up then almost dies again then levels off.
I've got 100 miles on it...is this because it's not broke in yet? It just doesnt seem right.
Timing is right (not adjustable)....new plugs and wires...checked for vacuum leaks.....all accessories worked fine on old engine.
Any ideas?
1990 YJ
PostPosted: Mon Aug 02, 2004 7:41 pm    Post subject: Reply with quote
Sounds like a sensor...my guess would be either TPS or CPS. Or it's possible something is wrong with the ECM itself . If you have access to a ODB reader (I believe that 90 was the last year for ODB and that it went to ODBII in 91), I'd see what it tells you.
Steve
PostPosted: Mon Aug 02, 2004 7:45 pm    Post subject: Reply with quote
Also, are you taking it easy on the new engine while you break it in? No long trips, lugging it, etc?
x-tatik
PostPosted: Tue Aug 03, 2004 6:43 am    Post subject: Reply with quote
yeah...I am breaking it in exactly how the FSM says.
maybe I should take it to autozone and see if they can pull the codes for me? I'm not getting a CEL but the bulb could be out.
1990 YJ
