OME LT shocks
Keithtj
ARLI$$
ARLI$$
PostPosted: Thu Aug 05, 2004 7:47 am    Post subject: OME LT shocks Reply with quote
I will soon be purchasing new shocks and was wondering if the OME long travels will work with an OME lift and 1" bl, now the bl doesn't affect the shock right? I want to uprgrade my suspension in the near future and was wondering if I should go ahead and get the LT's
My Morning Jacket
WhatWasIThinkin
PostPosted: Thu Aug 05, 2004 5:35 pm    Post subject: Reply with quote
Arent the LT's designed for 3.5+" lifts?
If you have the OME spring lift, just get the standard shocks, 942 and 933 if I remember correctly.
Real Jeeps dont wear Bra's
CoreyXJ
Turkish
Turkish
PostPosted: Thu Aug 05, 2004 8:11 pm    Post subject: Reply with quote
What I would probably do is get a bunch of old Coke cans and duct tape them together in 3 foot sections. Do this four times. Then get some fishing line, four small fence posts, and some thumb tacks. Use the fishing wire and thumb tacks to secure the Coke cans inside the section fence post, and be sure to load it up with a ton of axle grease to keep it from squeaking. HO Get er done! Once you get all those made up use some JB Weld to attached your shock ends to the top of the Coke cans and the bottom of the fence post, bolt them in your TJ and hit the trail!!!
Good luck getting home.....much less getting to the trail!
From all of us here at Redneck Riggin' It - Get er' Done !!!!
