98 XJ Door Lock
fernstin
PostPosted: Mon Oct 11, 2004 9:33 am    Post subject: 98 XJ Door Lock Reply with quote
I installed a new window regulator in the driver door this weekend and after I got it put back together the door lock wouldn't work.
I think I bent the little aluminum arm going from the electric lock motor to the door handle/lock button.The motor still works ok but the little rod seems to twist now instead of pushing the lock/unlock button.
Any suggestions would be much appreciated.
Thanks!
Embarassed
majikxms
PostPosted: Mon Oct 11, 2004 1:29 pm    Post subject: Reply with quote
When I put mine back together I didn't seat the wire harnass correctly so it didn't work right...try that, or are you convinced the metal arm is bent? Hit the Bone Yards if you do.
