Spring-over conversion for Cj7?
buckwheat1
PostPosted: Mon Oct 11, 2004 6:10 pm    Post subject: Spring-over conversion for Cj7? Reply with quote
Confused I'm thinking of doing a sping-over conv. on my '80 Cj7. Is it worth it? I've seen bolt-on applications from good companies. Are there any draw-backs? Can I use a shackle reverse still? I want the lift without modifying my drivetrain and all the pains with it. The suspention is in good shape,stock springs, power steering, 1 1/2 over shakles, 1" body lift, hd stock springs, winch. Gears are next. Whats the general opinion?
thanks.
PostPosted: Mon Oct 11, 2004 6:27 pm    Post subject: Re: Spring-over conversion for Cj7? Reply with quote
Explain this statement to me a little more. I'm curious what you mean by it.
PostPosted: Mon Oct 11, 2004 9:41 pm    Post subject: Reply with quote
Check out this site - some good info, but you'll likely need to lengthen your driveshafts and you'll need to modify your steering.
