PRELOAD PINION SPECS
aminoacid
PostPosted: Wed Oct 13, 2004 12:58 pm    Post subject: PRELOAD PINION SPECS Reply with quote
Hello. I"m installing new rear pinion bearings on a 96 grand cherokee with 3.55 gears and 249 transfer case. dana 35 axle
I needed to know the turning torque on that darn yoke nute and whether or not the gears and all have to be assembled when i'm tightening the nut for the pinion. Also if somebody has the carrier bearing torque specs that would be great.
Thanks a bunch in advance
Shocked
