86 Jeep Cherokee wheres the tps located????
shroomlady
PostPosted: Wed Oct 13, 2004 4:36 pm    Post subject: 86 Jeep Cherokee wheres the tps located???? Reply with quote
Embarassed I have a 86 Jeep Cherokee 4wd 5 speed 6 cyl. It has a carbeutor where is the tps sensor located???Help!!!!!!
PostPosted: Fri Oct 15, 2004 1:30 am    Post subject: Reply with quote
With a carb the TPS is usually internal...operational word there is "usually". With an 86 you prolly have the 2.8 V6, and thus the Rochester Varajet. I'm honestly not sure where the TPS is on that carb.
I'll see what I can find out.
Steve
shroomlady
PostPosted: Sun Oct 24, 2004 2:49 pm    Post subject: Reply with quote
Thanks Steve would really appreciate that....
jonathan
PostPosted: Thu Jan 06, 2005 10:33 pm    Post subject: Reply with quote
I've had the problem on a friends xj. I have an 86 also, but fuel injected. His sensor was on the back side of the carburator. It's hidden by the fuel lines/vaccum lines. it only has two wires vs. the normal three wires. And it screws in, usually a box wrench of a good set of small vise grips can get it out. If I remember right there's no adjustment for that sensor. It was a big problem for that year. So they changed it to what I have now.
detox
PostPosted: Fri Jan 07, 2005 3:41 am    Post subject: Reply with quote
i've heard that the carb should come off to get at the sensor properly.
Chicks Below Me...
88greenxj
PostPosted: Fri Jan 07, 2005 4:45 am    Post subject: Reply with quote
carbs dont have tps
88 xj 9.5 rustys lift custom 2 link front suspension 36 inch tsl
shroomlady
PostPosted: Fri Jan 07, 2005 2:34 pm    Post subject: Reply with quote
Thanks its still going nuts something is causing the RPM's to rev up not sure what....
