242 Problem with shifting
Brad S
PostPosted: Fri Oct 15, 2004 7:37 am    Post subject: 242 Problem with shifting Reply with quote
I completed the swap from my old 249 a while back and I have just been running my jeep in 2WD ever since.. No real need as of yet for 4WD.
I did; however, try to switch it into the 4Part Time, 4 Full and 4 Lo to see if they worked. What happened greatly disturbed me Sad
After I switch it into one of those modes, it seems to pull to the left really hard and makes kind of a groaning grinding noise. I was not happy! When I switched it back into 2WD it still pulled and grinded until I shook the lever around and popped it in and out of 4WD several times!
Any ideas to what the problem could be? I don't really NEED 4WD, but I kinda would like to have it...
PostPosted: Fri Oct 15, 2004 8:15 pm    Post subject: Reply with quote
Dont have a clue why it would pull to one side or the other... Maybe a front axle problem.. I dont know..
The grinding when shifting could be that you are not shifting correctly ..
You should be rolling 3-5 miles per hour and put Jeep in Neutral and while still rolling pull the t case to what ever gear you want then Tranny back in gear.. IF you try to do it while you are sitting still it will grind..
Like I said .. As far as pulling to one side that would almost be impossible to blame on the T case..
But I dont know where to put the blame..
Sorry..
Any other help??
