door lock problem on '98 laredo
irv6744
PostPosted: Thu Oct 21, 2004 5:39 pm    Post subject: door lock problem on '98 laredo Reply with quote
one of the the back door slide door locks is stuck on locked. can't slide it to unlocked. the master electric door lock switch doesn't help and the door cannot be opened from the inside or oustside. what to do. thanks
Buddha_Kip
PostPosted: Thu Oct 21, 2004 9:46 pm    Post subject: Reply with quote
gonna have to change the door latch
since you can't open the door, you'll probably have to unbolt the seat on that side (you can try skipping this and moving onto pulling the door panel, but the seat may have to come out)...two bolts per piece (I'm assuming you have the 60/40 split rear seat). Once you have the seat removed from that side, undo the screws from the door panel...should be one in the door-latch-pull and one in the door-pull "cup". Once you have these out, you'll be able to pull the panel off...just pull (being careful with the interior door latch handle...dont want to break that off). There should be 6 door retainer clips (if you break a few, don't really worry about it, they're cheap (less than a dollar for a couple in a package), and can be picked up at the local car parts store. Once the door panel is off, you can get to the door latch switch...just disconnect it from the motor, and pull the rod toward the nose of the truck to open the door. Once you have it open, you can replace the latch (I don't know the part number for the motor for a ZJ...for the WJ it's 55135 620AB (right) 55135 621AB (left).
edit - the part you need is $70.xx for a ZJ, and $45-ish for the WJ from http://www.tenaflyjeepmoparparts.com/sercolpar.html (just go through the "Service Repair Parts On-Line Catalog" link and plug in your info....will be under mechanical/body hardware/door/front\rear/lock...
PostPosted: Fri Oct 22, 2004 3:52 pm    Post subject: Reply with quote
Or you could do this...
Except with the back doors... rofl rofl rofl
Or you could just do what Kris says.... Mr. Green Mr. Green
Brad S
PostPosted: Fri Oct 22, 2004 10:18 pm    Post subject: Reply with quote
eh... it might look cool! thumbs
Buddha_Kip
PostPosted: Sat Oct 23, 2004 2:35 am    Post subject: Reply with quote
don't put any ideas into his head....no more cutting until the cage gets installed.
PostPosted: Sat Oct 23, 2004 5:34 am    Post subject: Reply with quote
yes... Cage first Cut later.. Very Happy Very Happy Very Happy
