What Is This
majikxms
PostPosted: Fri Nov 05, 2004 3:04 pm    Post subject: What Is This Reply with quote
I haven't looked in the FSM yet, but I have no idea what this is. It's got one vacuum tube out of the gas tank and two others. Anyway, anybody know what this is while I look it up. One of the connection tubes is broke. I have a 98 XJ. It's a black box under the metal plate that holds it in.
majikxms
PostPosted: Fri Nov 05, 2004 3:27 pm    Post subject: Reply with quote
Found it in the Emissions System section. That's the EVAP Canister.
DESCRIPTION
A maintenance free, EVAP canister is used on all
vehicles. The EVAP canister is located under the left
side of vehicle near the front of the rear axle.
OPERATION
The EVAP canister is filled with granules of an
activated carbon mixture. Fuel vapors entering the
EVAP canister are absorbed by the charcoal granules.
Fuel tank pressure vents into the EVAP canister.
Fuel vapors are temporarily held in the canister until
they can be drawn into the intake manifold. The duty
cycle EVAP canister purge solenoid allows the EVAP
canister to be purged at predetermined times and at
certain engine operating conditions.
CoreyXJ
Turkish
Turkish
PostPosted: Fri Nov 05, 2004 8:19 pm    Post subject: Reply with quote
Here this whole time I thought that thing was a dickfer.....
Mmm- Learn something new everyday!!
rofl rofl
Carl
PostPosted: Sat Nov 06, 2004 1:08 am    Post subject: Reply with quote
You know....you don't get all those dickfers and thingamajigs on an oil burner, Sooooo much simpler.
Go on, you know you want to....get a diesel. Mr. Green
99XJ 2.5TD Orvis. 2.5" OME lift. Airflow Snorkel with Centri Pre-Cleaner, other stuff too and an ever lighter wallet.
02TJ 4.0l Sahaha. 1" JKS body lift, front recovery hooks and a loud sound system.
