Auto Tranny fluid change and other maintenance
bmwperson
PostPosted: Wed Nov 17, 2004 12:37 am    Post subject: Reply with quote
ebay.. Im still having problems disassembling my tcase, I dont want to remove all the shafts if I dont have to... as of right now im stuck disassembling the input shaft, there is a metal cover on the mainshaft and I tried prying it out of there but that just bent it... also which shafts do I have to remove to disassemble the tcase (only to open the covers put new gasketmaker and put it back together)
Tom
PostPosted: Wed Nov 17, 2004 6:23 am    Post subject: Reply with quote
You dont have to remove any shafts to open the case..
Just make sure you have all the lock rings off the shaft and the case should come apart like this...
Make sure to look very carefully. The lock rings are all tucked up beside something..Outside of case or against bearings..
It should come open
On the 249 you have a clip inside the case that has to be held open while you slide the case apart...
It is located inside this cover...
Be carefull dont break anything trying to pry it open..
Let me know if you need any more help..
Carl
bmwperson
PostPosted: Wed Nov 17, 2004 12:57 pm    Post subject: Reply with quote
another question... does the space between the tranny and tcase have to be seal tight? should there be fluid in there at all? Im asking because I had a leak there and as I disassembled the whole thing I found out that there are 2 seals on each side one tranny one on the tcase so technicaly there shouldnt be any fluid in there thus there wouldnt be anything to leak thus it doesnt nessesarly have to be sealed there...
and whats the size of the bolt on the output yoke?
Thanks for your help Smile
Tom
bmwperson
PostPosted: Wed Nov 17, 2004 1:34 pm    Post subject: Reply with quote
ah you got the other side opened up and I think that requires a tool to remove the cover from the tail output flange.
Tom
PostPosted: Wed Nov 17, 2004 6:36 pm    Post subject: Reply with quote
Its a small allen wrench if I remember correctly.. Or maybe a Torx but it comes off...
I dont remember what the output Nut size was... 22MM maybe.. We need a shrug smiley... Very Happy
I put RTV on both surfaces even though I had new seals on tranny and t-case..
But figured just incase I would put the RTV there.. Mr. Green
bmwperson
PostPosted: Wed Nov 17, 2004 7:34 pm    Post subject: Reply with quote
hold on... I removed the input flange ring + output yoke(the ones facing the front of the car) but the case still wont open... you and the manual removed the other side of the case where the the tail shaft is.. there is a cover on the tailshaft and you need a puller (that i cant get anywhere) How did you manage to remove it? is there another way around it?
Tom
bmwperson
PostPosted: Wed Nov 17, 2004 10:38 pm    Post subject: Reply with quote
nm got it I guess I had to use a decent amount of force to get it off..
Tom
PostPosted: Thu Nov 18, 2004 6:02 am    Post subject: Reply with quote
Glad it worked out for you.. Wink
bmwperson
PostPosted: Thu Nov 18, 2004 12:51 pm    Post subject: Reply with quote
YET another problem, I still have to get a puller to remove that tailshaft cover to make a new seal.... Im looking for that puller but cant find it anywhere...
Tom
